IOCTL HAL GET WAKE SOURCE
This IOCTL returns the wake-up reason bits. This feature is available since Toradex WinCE BSP V3.4:
Define
#define     IOCTL_HAL_GET_WAKE_SOURCE   CTL_CODE(FILE_DEVICE_HAL, 42, METHOD_BUFFERED, FILE_ANY_ACCESS)
C source code sample
DWORD wakeReason[3];
KernelIoControl(IOCTL_HAL_GET_WAKE_SOURCE, NULL, 0, wakeReason, sizeof(wakeReason), NULL);
WakeReason format:
wakeReason[0] = SYSWAKE_OEMBASE; // is 0x800 or -1 when no wake-up was performed
// for a description of the following register values please refer to the Marvell PXA datasheets.
wakeReason[1] = PXA3xx: PWSR (Register address 0x40F50014),  PXA270: PEDR (Register address 0x40F00018)
wakeReason[2] = PXA3xx: AD3SR (Register address 0x40F4000C), PXA270: 0
