IOCTL HAL IRQEDGE
Using this IOCTL, you can define the edge on which the interrupt is triggered.
Define
#define IOCTL_HAL_IRQEDGE CTL_CODE(FILE_DEVICE_HAL, 2050, METHOD_BUFFERED,FILE_ANY_ACCESS)
Sample
You can find a sample in the SourceCode examples.
