LVDS (Lily)
Lily Version 1.1
The LVDS signals are routed into the FPGA and converted by default (reference design) to RGB, which is then converted to the DVI-I signal.
Is is possible to route the LVDS signal to an expansion header instead of the DVI-I. For doing this, you need to modify the FPGA design and reprogram the FPGA.
Lily Version 2.0
Lily Version 2.0 supports two assembly variants for the LVDS signals:
  • LVDS->RGB->VGA (implemented on Lily Version 2.0 Micro (for Woodpecker))
  • LVDS routed to a pin header (implemented on Lily Version 2.0 Nano (for Robin))
The LVDS signals are routed to header X26 (see datasheet for more information)
The LVDS signals are routed to a LVDS to RGB converter chip. The RGB signals are then converted to VGA signals, which are routed to the DVI-A interface.
Toradex can provide a reference design schematic free of charge upon request.
