MECS Tellurium USB Detect Patch
The USB client detect voltage divider is rather high-impedance which can be changed as follows:
  • Replace R13 with 0 Ohm resistor (was 10K).
  • Replace R14 with 56 Ohm resistor (was 56K).
  • Replace R15 with 100 Ohm resistor (was 100K).
