Microsoft Embedded Visual C++
Microsoft Embedded Visual C++ (eVC++) is a legacy tool and not supported by Microsoft and Toradex anymore. We recommend to use Visual Studio 2008 or Visual Studio 2013 depending on the Windows CE version you are using.
Microsoft Embedded Visual C++ (eVC++) can be used to develop applications for Colibri modules. It can be downloaded free of charge from the Microsoft homepage. The communication to the Colibri is done through USB ActiveSync which is also freely available from Microsoft. It is also possible to use [[Embedded Visual C++ over Ethernet|Ethernet for debugging]].
How to get EVC++ 4 working with WinCE 6.0 devices.
Microsoft Embedded Visual C++ does not official support Win CE 6.0. In order to make it work, you need to do the following steps:
  1. Copy the content of evc4_wce6.reg below into any text editor
  2. Replace all occurrences of the following paths to match your actual installation paths:
    C:\\Program Files\Microsoft eMbedded C++ 4.0\
    C:\\Program Files\Common Files\Microsoft Shared\Windows CE Tools\
  3. Save the modified content into a file evc4_wce6.reg.
  4. Double-click on new reg file to import it into your PC's registry.
  5. After importing the registry the eVC++ will start working on Windows CE 6 devices. There will be still some error messages but it is normal. Just close them by pressing YES.
evc4_wce6.reg
Windows Registry Editor Version 5.00
;registry file to make Embedded VisualC++ 4.0 running for Windows CE6 Devices
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{6538D4BA-BC24-4F7A-9F09-E8EBF6C6D984}]
@="jitdebugger.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{6538D4BA-BC24-4F7A-9F09-E8EBF6C6D984}\jitdebugger.exe]
"C:\\\\Program Files\\Microsoft eMbedded C++ 4.0\\evc\\wce500\\target\\armv4i\\jitdebugger.exe"=hex:02,\
00,00,00,08,00,00,00,00,00,02,05,00,00,00,00,00,10,00,00,06,00,00,00,00,00,\
00,00,08,00,00,00,3a,34,dc,7c,bd,06,b3,47,98,93,75,0e,76,35,01,17
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{72B8A756-A6A6-44C1-9454-30438DAF84F4}]
@="cemon.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{72B8A756-A6A6-44C1-9454-30438DAF84F4}\cemon.exe]
"C:\\\\Program Files\\Microsoft eMbedded C++ 4.0\\evc\\wce400\\target\\armv4i\\cemon.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}]
@="Packages"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{0291450A-A979-4AC5-AAFF-54B923A76BD9}]
@="Windows CE Remote Zoom_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{0291450A-A979-4AC5-AAFF-54B923A76BD9}\cezcli.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cezcli.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{09C004A1-9290-4AC0-8F19-B171F1AE08CF}]
@="Toolhelp_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{09C004A1-9290-4AC0-8F19-B171F1AE08CF}\toolhelp.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\toolhelp.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{4E64D030-48FF-11D2-975C-00A0240918F0}]
@="Toolhelp"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{4E64D030-48FF-11D2-975C-00A0240918F0}\toolhelp.dll]
00,00,08,00,00,00,21,22,3c,cc,1b,05,80,4d,a0,95,93,d4,60,86,e7,80
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{677620BC-8DD4-4A38-8DA3-093E6A11C4E8}]
@="Windows CE Remote Process Viewer_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{677620BC-8DD4-4A38-8DA3-093E6A11C4E8}\cepwcli.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cepwcli.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{69793847-677E-4658-92D3-B32A2ED13FE4}]
@="CEMGR Client Component"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{69793847-677E-4658-92D3-B32A2ED13FE4}\cemgrc.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cemgrc.exe"=hex:02,\
00,00,00,05,00,00,00,00,00,01,05,00,00,00,00,00,10,00,00,06,00,00,00,00,00,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{69793847-677E-4658-92D3-B32A2ED13FE4}\cetlstub.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cetlstub.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{75B47A4E-323A-41A3-9058-CD68E739ABD6}]
@="Windows CE Remote Registry Editor_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{75B47A4E-323A-41A3-9058-CD68E739ABD6}\ceregcli.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\ceregcli.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{78D77BC6-37CF-4FDB-BF45-72C891831314}]
@="Windows CE Remote Heap Walker_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{78D77BC6-37CF-4FDB-BF45-72C891831314}\cehwcli.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cehwcli.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{8230BAED-0EF3-4AA7-A96A-F4A4021B01EC}]
@="TCP/IP Transport"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{8230BAED-0EF3-4AA7-A96A-F4A4021B01EC}\tcpipc.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\tcpipc.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{BEA79E99-0B2F-4FAC-BAF2-BCFF83E56879}]
@="Windows CE Remote Spy_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{BEA79E99-0B2F-4FAC-BAF2-BCFF83E56879}\cespycli.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cespycli.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{C600E2C0-9022-4B42-8B29-F705F4FF4ECD}]
@="Windows CE Remote System Information_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{C600E2C0-9022-4B42-8B29-F705F4FF4ECD}\CESysInfo.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\CESysInfo.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{C92C56B8-1394-4155-8016-3FD669E3EE3C}]
@="ActiveSync Transport"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{C92C56B8-1394-4155-8016-3FD669E3EE3C}\tlcesrv.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\tlcesrv.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{CA443ABA-3F32-48B3-BDE7-C30249BEA763}]
@="Windows CE Remote Performance Monitor_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{CA443ABA-3F32-48B3-BDE7-C30249BEA763}\CEPerfMon.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\CEPerfMon.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{CA443ABA-3F32-48B3-BDE7-C30249BEA763}\IPHLPAPI.DLL]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\IPHLPAPI.DLL"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{CA443ABA-3F32-48B3-BDE7-C30249BEA763}\toolhelp.dll]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{E3ABDA1B-2C77-49A9-BB0E-BB65B5788E48}]
@="CE Kernel Tracker Publisher_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{E3ABDA1B-2C77-49A9-BB0E-BB65B5788E48}\celog.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\celog.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{E3ABDA1B-2C77-49A9-BB0E-BB65B5788E48}\KTPub.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\KTPub.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F1B5AEB8-CB03-4C62-A405-A6CB65DDF34A}]
@="RCOM_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F1B5AEB8-CB03-4C62-A405-A6CB65DDF34A}\PSPubSubCE.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\PSPubSubCE.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F1B5AEB8-CB03-4C62-A405-A6CB65DDF34A}\rth.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\rth.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F1B5AEB8-CB03-4C62-A405-A6CB65DDF34A}\rtsce.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\rtsce.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F2062C0A-B025-4ED1-8E02-78DBDBEC9D15}]
@="KITL Transport for Platform Builder"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F2062C0A-B025-4ED1-8E02-78DBDBEC9D15}\cetlkitl.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cetlkitl.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F20ACF78-1F03-43C3-A90C-B5D7E53F23EE}]
@="CE Profiler Publisher_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F20ACF78-1F03-43C3-A90C-B5D7E53F23EE}\cecap.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cecap.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F20ACF78-1F03-43C3-A90C-B5D7E53F23EE}\celog.dll]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F20ACF78-1F03-43C3-A90C-B5D7E53F23EE}\conpmon.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\conpmon.exe"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F20ACF78-1F03-43C3-A90C-B5D7E53F23EE}\msitlogr.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\msitlogr.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F20ACF78-1F03-43C3-A90C-B5D7E53F23EE}\profilepub.dll]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\profilepub.dll"=hex:02,\
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F53D4F46-8415-4A3D-B75A-E96A2C0BA4ED}]
@="Windows CE Remote File Viewer_500"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Tools\Platform Manager\{2A4F783A-014E-11D2-BBA0-00A0C9C9CCEE}\{F53D4F46-8415-4A3D-B75A-E96A2C0BA4ED}\cefwcli.exe]
"C:\\\\Program Files\\Common Files\\Microsoft Shared\\Windows CE Tools\\Platman\\\\target\\wce500\\armv4i\\cefwcli.exe"=hex:02,\
