Mini PCI Express Serial Adapter
Tags
Attach and Install Mini PCI Express Serial Adapter driver
The PEX1S1PMINI from StarTech.com is a Mini PCI Express Serial Adapter, compatible with Daisy and Lily.
Attach Mini PCI Express Card before powering on module and baseboard.
Boot the operating system and install the latest drivers from StarTech.com.
Check the Connection Manager for successful integration of the new Hardware into the system.
![](/files/toradex-dev/uploads/images/wiki/Mini_PCI_Express 003.png)
The Mini PCI Express Serial Adapter adds an easy to install Serial Port to the Baseboard.
