Mouse Cursor
Hide the Mouse Cursor
Hide Mouse Cursor by Registry Setting
For Colibri PXAxxx
You can hide the mouse cursor in the Display driver registry settings.
[HKLM\Drivers\Display\Colibri]
cursor=dword:0
You must save the registry.
For Colibri T20
  1. Open RegEdit by going to Start > Programs > ColibriTools > RegEdit
  2. Make the following change:
    HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\NVDDI
    "HwCursor"=dword:0
  3. Save the registry using SaveReg in ColibriTools.
  4. Restart the module.
For Colibri/Apalis i.mx6
    HKEY_LOCAL_MACHINE\Drivers\Display
    "Cursor"=dword:0
Hide Mouse Curser Globally From an Application
You can call an escape code to globally enable/disable the mouse cursor.
#define ESCAPECODEBASE          100000
#define MOUSECURSOR             (ESCAPECODEBASE + 20)
DWORD old_cursor=0;
DWORD new_cursor=0;
// Get Cursor Status
ExtEscape(GetDC(NULL), MOUSECURSOR, 0, NULL, 4, (char*)&old_cursor);
// Disable Cursor
new_cursor=0;
ExtEscape(GetDC(NULL), MOUSECURSOR, 4, (char*)&new_cursor, 4, (char*)&old_cursor);
// Enable Cursor
new_cursor=1;
Hide the Mouse Cursor for one Application
There is an API call to hide the mouse cursor for only one application
    ShowCursor(FALSE);
