Network Messages Suppress (Hide) from NETUI
Tags
NETUI is responsible for network or Ethernet message and network login access dialog pop-ups. Most of the applications do not need to show these message and dialog pop-ups. We have implemented a registry configuration to suppress or hide them and application can receive these messages using the message queues.
Disable NETUI message box and dialogs
Disable NETUI message box and dialogs by adding the following registry:
[HKEY_LOCAL_MACHINE\Software\NETUI]
“SuppressPopups” = DWORD:1
After registry entry, save the registry.
Code to receive NETUI messages in an application
