NRESET IN
The nRESET_IN pin (also RESET_EXT) is used to reset the Colibri module.
Common Specification
  • It has to be asserted for at least 35ms for proper resetting the module.
  • Low Voltage max. 0.4V
  • High Voltage min. 2.3V
  • It is weak Pull-up'd on the Colibri modules. If externally used, use an additional 10k Pull-up.
Also the Voltage monitoring can reset the module if the voltage drops.
Specification for the different modules
Colibri PXA270 with TPS65020
  • Time Low Min. 35ms (Deglitch)
  • High Voltage Min. 1.37V
  • Low Voltage Max. 0.4V
Colibri PXA3xx with MAX8660
  • Time Low Min. 1 uS
  • High Voltage Min. 1.4V
Colibri PXA3xx with LP3972
  • Time Low Min. tdb
  • High Voltage Min. 2.3V
  • Low Voltage Max. 0.5V
Colibri T20
  • Time Low Min. 16 uS
  • Time Low Max. 60 mS
