Overlay Lib API
Library of support functions for Overlays.
Data Structures
struct  XLLP_OVERLAY_T
Macros
#define  OVL_VER_MAJ  0
#define  OVL_VER_MIN  2
#define  OVL_VER_BUILD  1
#define  FORMAT_RGB  0x0
#define  FORMAT_PACKED_444  0x1
#define  FORMAT_PLANAR_444  0x2
#define  FORMAT_PLANAR_422  0x3
#define  FORMAT_PLANAR_420  0x4
#define  BPP_1  0x001
#define  BPP_2  0x002
#define  BPP_4  0x004
#define  BPP_8  0x008
#define  BPP_16  0x010
#define  BPP_18  0x020
#define  BPP_18_PACKED  0x040
#define  BPP_19  0x080
#define  BPP_19_PACKED  0x100
#define  BPP_24  0x200
#define  BPP_25  0x400
#define  O_BPP_4  0x2
#define  O_BPP_8  0x3
#define  O_BPP_16  0x4
#define  O_BPP_18  0x5
#define  O_BPP_18_PACKED  0x6
#define  O_BPP_19  0x7
#define  O_BPP_19_PACKED  0x8
#define  O_BPP_24  0x9
#define  O_BPP_25  0xA
Functions
void  OVLGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL  LCDInit (void)
void  LCDDeInit (void)
void  LCDDegrade (BOOL degrade, DWORD color)
BOOL  Overlay_Setup (P_XLLP_OVERLAY_T pXllpOverlay)
BOOL  Overlay_Enable (P_XLLP_OVERLAY_T pXllpOverlay)
void  Overlay_Disable (P_XLLP_OVERLAY_T pOv)
void  Overlay_GetBuffer (P_XLLP_OVERLAY_T pOv)
void  Overlay_Flip (P_XLLP_OVERLAY_T pOv)
BOOL  Overlay_PosSizeFormat (P_XLLP_OVERLAY_T pOv)
void  SetTransparencyFactor (DWORD n)
BOOL  Overlay2_Setup (P_XLLP_OVERLAY_T pXllpOverlay)
void  Overlay2_Flip (P_XLLP_OVERLAY_T pOv)
void  Overlay2_GetBuffer (P_XLLP_OVERLAY_T pOv)
void  Overlay2_Disable (P_XLLP_OVERLAY_T pXllpOverlay)
void  Overlay2_Enable (P_XLLP_OVERLAY_T pXllpOverlay)
#define BPP_1   0x001
#define BPP_2   0x002
#define BPP_4   0x004
#define BPP_8   0x008
#define O_BPP_4   0x2
#define O_BPP_8   0x3
Typedef Documentation
typedef struct XLLP_OVERLAY_T * P_XLLP_OVERLAY_T
Function Documentation
void LCDDegrade ( BOOL  degrade,
DWORD  color
Degrades the dispay to 1 bit per pixel (to save bandwidth)
Parameters
[in] degrade TRUE: Degrade, FALSE: Normal display
[in] color Palette color entry
void LCDDeInit ( void  )
Release the library - call when finished with the library
Return values
TRUE = Success
BOOL LCDInit ( void  )
Initialise the library - call before using other functions
Return values
TRUE = Success
void Overlay2_Disable ( P_XLLP_OVERLAY_T pXllpOverlay )
Disable the overlay - deprecated
Parameters
[in] pXllpOverlay Pointer to Overlay data structure
[out] pXllpOverlay Pointer to Overlay data structure
Deprecated:
void Overlay2_Enable ( P_XLLP_OVERLAY_T pXllpOverlay )
Enable the overlay - deprecated
Parameters
Deprecated:
void Overlay2_Flip ( P_XLLP_OVERLAY_T pOv )
Flip the overlay - deprecated
Parameters
[in] pOv Pointer to Overlay data structure
[out] pOv Pointer to Overlay data structure
Deprecated:
void Overlay2_GetBuffer ( P_XLLP_OVERLAY_T pOv )
Get the overlay buffer - deprecated
Parameters
Deprecated:
BOOL Overlay2_Setup ( P_XLLP_OVERLAY_T pXllpOverlay )
Setup the overlay - deprecated
Parameters
Deprecated:
void Overlay_Disable ( P_XLLP_OVERLAY_T pOv )
Disable the overlay
Parameters
BOOL Overlay_Enable ( P_XLLP_OVERLAY_T pXllpOverlay )
Enable the overlay
Parameters
Return values
TRUE = Success
void Overlay_Flip ( P_XLLP_OVERLAY_T pOv )
Flip the overlay buffer
Parameters
void Overlay_GetBuffer ( P_XLLP_OVERLAY_T pOv )
Parameters
BOOL Overlay_PosSizeFormat ( P_XLLP_OVERLAY_T pOv )
Update the overlay Position, Size and Format
Parameters
Return values
TRUE = Success
BOOL Overlay_Setup ( P_XLLP_OVERLAY_T pXllpOverlay )
Setup the overlay
Parameters
Return values
TRUE = Success
void OVLGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
Get the library Version.
Parameters
[out] pVerMaj Major version number.
[out] pVerMin Minor version number.
[out] pBuild Build number.
void SetTransparencyFactor ( DWORD  n )
Set the overlay transparency factor
Parameters
[in] n Transparency level, 0: very transparent, 7: fully opaque
