Power Manager registry settings
You can find the registry settings for the suspend mode in:
[HKLM\System\PM]
It is not required to restart the system after changes made in these registry keys. You can use IOCTL_HAL_RELOADPMPARAMS to reload the settings.
If no setting is present, the default value is taken. Just add the values to the registry to change them.
[HKLM\System\PM]
"NoSleepOnPowerFail"=dword:1 ;Added option to disable the Automatic entry in DeepSleep
                                ;on Voltage Fault detection. (This was causing troubles in
                                ;some cases where current consumption was high). Defualt = 0;
"SDRAMAPD"=dword:1           ;SDRAM Autopower down
                                ;1(default)  Enabled in CPU idle
                                ;2 always enabled
                                ;3 always off
"Idle"=dword:1               ;CPU Idle mode
                                ;0 CPU will never enter Idle mode
                                ;1 (default) CPU will enter Idle mode
"IdlePatch"=dword:0          ;CPU Idle patch selection
                                ;0 CPU enters Idlemode immediately (default for PXA270 and PXA3xx when not running @ 806MHz or 403MHz)
                                ;1 Method one (default for PXA3xx @ 806MHz or 403MHz)
                                ;              Change freq. to 104, idle, then back to 806 (requires full freq change)
                                ;2 Method two  Change freq. to 403, idle, then back to 806 (faster as it can be done with turbo freq change but not confirmed by Marvell)
