SD Memory Card Standards
All Colibri modules are HW compatible with at least the following SD Memory Card standards:
  • SDSC (SD Standard Capacity)
  • SDHC (SD High Capacity)
  • SDXC (SD eXtended Capacity)
Support with Windows CE
There might be limitations because of the used file system. The default file system on SDXC cards is exFAT which isn't supported by Windows CE5. Using SDXC cards is still possible under Windows CE5 when using e.g. FAT32. Windows CE6 and Windows Embedded Compact 7 support exFAT.
Multiple SD Card interfaces on Colibri PXAxxx
Please check this article to know how to enable multiple SD Card interface on Colibri PXAxxx modules.
Multiple SD Card interfaces on Colibri Txx
Please check this article to know how to enable multiple SD Card interface on Colibri Txx modules.
