SD/MMC Card (Linux)
Tags
SD/MMC-Cards which use the MMC subsystem are available as block device through /media/mmcblk{id}. The kernel normally parses the partition table and exports the partitions of the card using the appendix p{x}, e.g. /media/mmcblk{id}p{x}.
The bootlog shows the detection of the SDHCI controller:
[    6.861764] sdhci: Secure Digital Host Controller Interface driver
[    6.870575] sdhci: Copyright(c) Pierre Ossman
[    6.877645] sdhci-pltfm: SDHCI platform and OF driver helper
[    6.885949] sdhci_tegra_init+ #####
[    6.892317] sdhci-tegra sdhci-tegra.3: vddio_sdmmc regulator not found: -19.Assuming vddio_sdmmc is not required.
[    6.908111] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -19. Assuming vddio_sd_slot is not required.
[    6.924626] mmc0: Invalid maximum block size, assuming 512 bytes
[    6.933627] mmc0: no vmmc regulator found
[    6.940763] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[    6.954955] sdhci_tegra_init- #####
Before inserting any card no interrupts are generated yet:
root@colibri-t20:~# cat /proc/interrupts | grep mmc
 63:          0          0       GIC  mmc0
215:          0          0      GPIO  mmc0
And the IOs debugging information is not valid yet:
root@colibri-t20:~# cat /sys/kernel/debug/mmc0/ios
clock:          0 Hz
vdd:            0 (invalid)
bus mode:       1 (open drain)
chip select:    0 (don't care)
power mode:     0 (off)
bus width:      0 (1 bits)
timing spec:    0 (legacy)
SD/MMC Card Insertion
On insertion the kernel starts scanning the card in order to create devices for each partition. Depending on the Automount configuration the detected file systems get mounted automatically.
[  229.601281] mmc0: host does not support reading read-only switch. assuming write-enable.
[  229.611762] mmc0: new high speed SDHC card at address 0007
[  229.619048] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
[  229.626557]  mmcblk0: p1
Interrupts are happening (note one card detect GPIO interrupt thereof):
 63:       1336          0       GIC  mmc0
215:          1          0      GPIO  mmc0
And the IOs debugging information should now show valid information about the inserted card:
clock:          48000000 Hz
vdd:            20 (3.2 ~ 3.3 V)
bus mode:       2 (push-pull)
power mode:     2 (on)
bus width:      2 (4 bits)
timing spec:    2 (sd high-speed)
More specifics about the inserted card can be found in its CID/CSD:
root@colibri-t20:~# cat /sys/bus/mmc/devices/mmc0\:0007/cid
41343253443847423000066bf800d100
root@colibri-t20:~# cat /sys/bus/mmc/devices/mmc0\:0007/csd
400e00325b5900003b5f7f800a400000
The utility df shows the usage of the SD/MMC card:
root@colibri-t20:~# df | grep mmc
/dev/mmcblk0p1         7766188    434768   7331420   6% /media/733D-4531
And mount shows the mounting status:
root@colibri-t20:~# mount | grep mmc
/dev/mmcblk0p1 on /media/733D-4531 type vfat (rw,nosuid,nodev,relatime,gid=6,fmask=0007,dmask=0007,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro,uhelper=udisks)
From regular SD cards one should be able to read with sustained data rates of around 10 to 20 MB/sec:
root@colibri-t20:~# hdparm -t /dev/mmcblk0
/dev/mmcblk0:
 Timing buffered disk reads:  34 MB in  3.16 seconds =  10.75 MB/sec
SD/MMC Card Removal
Kernel message:
[  988.230735] mmc0: card 0007 removed
Triggered by another card detection interrupt:
 63:       1340          0       GIC  mmc0
215:          2          0      GPIO  mmc0
Optional UHS-I Support on Apalis T30
Apalis T30 V1.1A and later using our Embedded Linux BSP V2.3 beta 5 and later optionally support UHS-I (ultra high speed) cards in the 8-bit SD/MMC slot which require switching the IO voltage to 1.8 volts to achieve their full speeds.
Note: Please make sure your carrier board does not pull-up any of the MMC1 signals to 3.3 volt (e.g. remove R46 to R54 on our Apalis Evaluation Board V1.1A) before attempting to activate this feature.
Activation
This feature of the Linux SDHCI driver can be activated using the mmc_uhs kernel parameter, which can be set either from within U-Boot or Linux as follows:
U-Boot
setenv defargs 'core_edp_mv=1300 usb_high_speed=1 mmc_uhs=1'
saveenv
Linux
fw_setenv defargs 'core_edp_mv=1300 usb_high_speed=1 mmc_uhs=1'
UHS-I Card with mmc_uhs=1
[   42.946377] mmc1: host does not support reading read-only switch. assuming write-enable.
[   42.957696] mmc1: new ultra high speed DDR SDHC card at address 1234
[   42.966791] mmcblk1: mmc1:1234 SA08G 7.42 GiB
[   42.973415]  mmcblk1: p1
root@apalis-t30:~# cat /sys/kernel/debug/mmc1/ios
clock:          50000000 Hz
vdd:            17 (2.9 ~ 3.0 V)
power mode:     2 (on)
timing spec:    5 (invalid)
oot@apalis-t30:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
 Timing buffered disk reads:  98 MB in  3.04 seconds =  32.25 MB/sec
root@apalis-t30:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
 Timing buffered disk reads:  98 MB in  3.03 seconds =  32.38 MB/sec
/dev/mmcblk1:
 Timing buffered disk reads:  98 MB in  3.02 seconds =  32.41 MB/sec
UHS-I Card without mmc_uhs=1
[   68.134332] mmc1: host does not support reading read-only switch. assuming write-enable.
[   68.144952] mmc1: new high speed SDHC card at address 1234
[   68.152959] mmcblk1: mmc1:1234 SA08G 7.42 GiB
[   68.161914]  mmcblk1: p1
clock:          50000000 Hz
power mode:     2 (on)
/dev/mmcblk1:
 Timing buffered disk reads:  56 MB in  3.03 seconds =  18.46 MB/sec
/dev/mmcblk1:
 Timing buffered disk reads:  56 MB in  3.03 seconds =  18.45 MB/sec
/dev/mmcblk1:
 Timing buffered disk reads:  56 MB in  3.04 seconds =  18.44 MB/sec
