Shock and Vibration Tests
Shock and vibration tests compliance is an important measure for many industries. Many people are worried about these tests when it comes to modules. However, it isn't a problem for our modules and the module approach in general to comply with many different standards. The following tests were successfully passed by using a Colibri PXA310, module, the Colibri Fastener V1.0 and a normal SODIMM connector (Tyco 1473005-1).
Vibration
ISO 16750-3
10-2000Hz @ 58m/s²
EN 60068-2-64:2009
10-2000Hz @ 49m/s²
EN 60068-2-6:2008
2-500Hz @ 20m/s²
Shock
IEC 60068-2-72
40G for 11ms
