SODIMM (Woodpecker)
The Woodpecker Z5xx Module features a SODIMM connector for DDR2 Memory Modules. The following characteristics must be considered by choosing a suitable memory module.
Required SODIMM Characteristics
Attribute Values
SODIMM Organization x64 bits
Dimension (nominal) 30.0 mm high, 67.60 mm wide / MO-224 variation CB
SODIMM Type Supported Unbuffered
Pin count 200
SDRAM supported 512Mb, 1Gb and 2Gb
Capacity 512MB, 1GB and 2GB
Serial Present detect Consistent with JEDEC rev 1.1
Voltage Options (nominal) VCCSM 1.8V
Interface SSTL_18
Supported Memory Configuration
  • 8 DDR2 SDRAMs with x16 SDRAM organization in 2 ranks (JEDEC Raw Card A,G)
  • 4 DDR2 SDRAMs with x16 SDRAM organization in 1 rank (JEDEC Raw Card C,H)
  • 8 DDR2 SDRAMs with x8 SDRAM organization in 1 rank (JEDEC Raw Card B)
  • 16 DDR2 SDRAMs with x8 SDRAM organization in 2 ranks (JEDEC Raw Card E)
Toradex Tested SODIMM
512 MByte
  • Micron MT4HTF6464HY
1 GByte
  • Micron MT8HTF12864HDY
  • Samsung M470T2864QZ3-CF7
  • Swissbit SEN01G64E1CE2MT-30R
2 GByte
  • Transcend TS256MSQ64V8U 2GB DDR2 800 SODIMM
