SYS EN
How to get SYS_EN from Colibri modules
Colibri PXA270
  • Colibri PXA270 up to V1.2
    The SYS_EN signal is not available on Colibri PXA270.
Colibri PXA3xx
  • Colibri PXA300
    The SYS_EN signal is available on SODIMM pin 1. Since audio codec is not supported on Colibri PXA300, the SYS_EN signal is the only connected to PXA processor via a 10 kohm series resistor.
  • Colibri PXA300 XT / Colibri PXA310
    The SYS_EN signal is available on SODIMM pin 1. This signal is multiplexed with the MIC_IN signal as represented in the image below. There is a special capacitor circuit to split the two signals.
  • Colibri PXA320
    The SYS_EN signal is not available on Colibri PXA320.
To get the SYS_EN signal see the following circuit:
Colibri Txx, Colibri VFxx and Colibri iMX6
The SYS_EN signal is not available on these Colibri modules.
