Temperature Readout (Robin, Woodpecker)
Tags
The temperatures of Robin and Woodpecker can be read out with HWMonitor on Windows based Systems:
  • THM2 shows the Module temperature read by the external sensor chip and the minimum and maximum temperature mesured during the running cycle.
  • THRM shows the CPU temperature read by the external sensor chip and the minimum and maximum temperature mesured during the running cycle.
  • TZ01 shows the temperature of the DTS (Digital Thermal Sensor) and the minimum and maximum temperature mesured during the running cycle.
  • Core#0 shows the temperature of the DTS (Digital Thermal Sensor) and the minimum and maximum temperature mesured during the running cycle. This is done by the app itself and is not returned by the BIOS.
Remarks
  • TZ01 and Core#0 doesn't work properly below 55°C
  • Core#0 is read by the CPUID tool itself
  • TZ01 is read by the BIOS and provided over ACPI
  • TZ01 must be enabled in the BIOS under "Power Mangement"
  • Alternatively SpeedFan can be used
  • THM2 is not available before BIOS Versions XXX0019
Software Development Kit
The HWMonitor's PC health monitoring engine is available for customized use through the CPUID System Monitoring Development Kit, a professional SDK built for the Microsoft Windows operating systems. HWMonitor is available at www.cpuid.com
