Thermal Solution (Woodpecker, Robin)
In general, Robin and Woodpecker need a thermal solution. This may be:
Exceptions can be:
  • Woodpecker/Robin Z510 running in cold environment
  • Woodpecker/Robin Z510 running in environment with high air flow
Woodpecker has the doubled PCB size than Robin, hence the thermal management on Woodpecker is less critical.
