Touch Tweak
TouchTweak needs image version 3.2 beta1 and onwards.
You can find the tool in the Colibri Software.
Description
With this tool, you can adjust the touch screen driver to your touch screen if required.
Parameter Descriptions
Sampling Interval
Interval between 2 touch measurements in milliseconds. One measurement includes X,Y, and pressure.
SampleWait
Time to wait for each ADC conversion (Should be set to 0)
Dummy Samples
Number of samples measured at the beginning for each X, Y, and pressure but not processed. (can normally be set to 0)
Samples
Samples to process (they will be averaged)
Wait(X/Y/Pressure)
Time to wait before starting the sampling of the corresponding measurement (X/Y/Pressure). On large touch panels or when using large filter capacitors, higher values must be set to let the touch settle into the right measurement mode)
Max Variance(X/Y/Pressure)
The Driver will sample many values for each measurement (X/Y/Pressure) and if one of these values is too large or small from the other sample values, the whole measurement is invalidated. The Max Variance defines this maximum difference between all samples.
Min Pressure
Minimum pressure needed to validate all measurements. If the pressure is below this level, all X/Y measurement will be discarded. 0 means no pressure measurement is done.
Sensitivity
Sensitivity for the pen or finger down detection. Range from 1 (most sensitive) to 63 (less sensitive). Wolfson codecs only.
Filter
This will enable an ADC internal Analog LowPass filter. UCB1400 codec only.
