Vybrid Display Tool
Tags
You can adjust the display registry settings directly using the Vybrid Display Tool. The tool provides an interactive graphical interface with all the display settings supported by the display driver through registry. Previously, we used this functionality as a part of our Colibri Tweak tool, but for better maintainability, we have now split it into a separate display tool for the Vybrid modules only.
Features
The features are further subdivided into specific configurations to provide a better understanding of the tool.
  • Display Hardware Configuration
BPP Specify the bit per pixel which is used in the internal frame buffer. LDDS Specify the number of data lines which are used to connect the display. hsp Polarity of the Hsync signal. vsp Polarity of the Vsync signal. pcp Polarity of the pixel clock signal.
  • Display Timings
Pixel Clock(pclk) Configure the pixel clock frequency.
hsw               Horizontal Sync Width. Sync setup time in clocks.
blw               Beginning of Line/Beginning of Frame Pixel Clock Wait Count. (Back Porch in clocks. Yes, our "front" is the back porch).
CxScreen          Here you can set the horizontal resolution of your display.
elw               End of line width. Sync setup time in clocks.
vsw               Vertical sync width.
bfw               Beginning of frame width (Back Porch).
CyScreen          Here you can set the vertical resolution of your display.
efw               End of frame width.
  • Special Features
VideoRAMSize      Allocated memory for display driver in Bytes.
FirstRefreshDelay Value of refresh delay.
LCDBS             Display signal buffer strength.
BL_GPIO           GPIO Used to turn ON/Off Backlight.
BL_POL            Polarity for Backlight GPIO.
UseSplashSettings Uses the configuration used for the splash screen.
Rotate            Rotate display to according to the requirement.
  • Buttons
SavePreset        Save the current display settings to a .reg file.
Preset            Select available display prestes from the ComboBox. Preset file/s should be located in "DisplayPreset" folder. Application binary and "DisplayPresets" should be kept in the same directory.
RegSave           Save the display settings to the Registry and save the registry to the flash memory.
ConfigSave        Save the display settings to the Config Block. This is used to modify the splash screen display settings
Note:
  • To get the correct range of supported values from the display driver, read the Display Driver Registry Settings article.
  • As per the registry settings by default UseSplashSettings are enabled, to see desired changes in display driver according to the settings un-check the checkbox.
  • For changes in display setting to take effect, reboot the module.
Downloads
Please find the download link for the respective OS to be mentioned below:
Tool WinCE6, WEC7 WEC2013
VybridDisplayTool V1.1 V1.1
