Wakeup sources
See the list of pins that are able to wake-up the Colibri module from Suspend-mode. See Suspend registry settings for information about how to configure wakeup sources in the registry.
Colibri PXA 270
  • GPIO:
Each of these:      0-15, 16-17, 34, 35, 39, 83, 90, 91, 93-102, 116
Only one of these:  31 or 113
Only one of these:  38 or 36 or 40 or 53
Colibri PXA 320
  • SODIMM:
Each of these:
019,021,023,025,027,029,030,031,032,033,034,035,036,037,038,043,045,049,051,053,054,
055,057,061,063,065,066,069,073,075,077,081,085,086,088,090,092,093,095,096,100,101,
102,103,104,106,107,118,120,122,124,127,129,131,134,135,136,137,138,140,142,144,146,
150,152,154,156,158,160,162,164,166,168,170,172,174,176,180,190,192,194,196
043: This pin is always sensitive on both edges!
064,099,133: These pins could be used as wakeup under special circumstances but we
                advise to NOT use them!
  • EXTCONN:
Each of these:
01,02,03,05,06,07,08,09,10,11,12,13,14,15,16,17,18
Colibri PXA 300/300 XT/310
  • SODIMM:
Each of these on PXA 300/300 XT/010:
019,021,023,025,027,028,029,030,031,032,033,034,035,036,037,038,045,047,049,050,051,
052,053,054,055,057,059,061,063,064,065,066,069,074,081,085,086,088,090,092,093,095,
099,100,102,104,105,106,107,118,120,122,124,127,129,131,133,135,136,137,138,140,142,
144,146,152,154,156,158,160,174,176,184,190,192,194,196
050,064,066,074,099,133: These pins could be used as wakeup under special
                            circumstances but we advise to NOT use them!
On PXA300/300 XT only:
004,006,014,016,018,020,073,075,077,150,162,164,166,168,170,172,180
On PXA310 only:
178: This pin could be used as wakeup under special circumstances but we advise
        to NOT use it!
  • EXTCONN:
Each of these on PXA300/300 XT/310:
On PXA310 only:
04: This pin could be used as wakeup under special circumstances but we advise
       to NOT use it!
Colibri T20
  • SODIMM:
37, 38, 43, 45, 49, 55, 73, 103, 116, 118, 129, 131, 135, 178
For limitations on the Tegra modules see: Wakeup Sources on Colibri T20 and Colibri T30 - Known Limitations
Colibri VF50/VF61
  • SODIMM:
19, 21, 24, 27, 30, 33, 43, 45, 50, 59, 63, 81, 94, 95, 196
