Watchdog Lib API
WatchDog Support Library.
Macros
#define  WATCHDOG_VER_MAJ  1
Major Library Version.
#define  WATCHDOG_VER_MIN  0
Library Subversion.
#define  WATCHDOG_VER_BUILD  0
Library Build.
Functions
void  WatchdogGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL  WatchdogInit (void)
BOOL  WatchdogDeinit (void)
BOOL  WatchdogRetrigger (DWORD Timeout_ms)
Detailed Description
Author
$Author$
Version
$Rev$
Date
$Date$
Test:
Colibri PXA320, Windows CE 6.0
Target Platforms:
PXAxxx
Caveats:
The watchdog does not work on PXA270 due to bug in the PXA270 CPU.
Library Build.
Library Subversion.
Function Documentation
BOOL WatchdogDeinit ( void  )
Deactivate watchdog
This is not possible, therefore the function always returns FALSE
Return values
TRUE = success
FALSE = error
void WatchdogGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
returns the version of this library
Parameters
[out] pVerMaj Main Version of this library
[out] pVerMin Subversion of this library
[out] pBuild Build Number of this library
BOOL WatchdogInit ( void  )
Activates the watchdog, and sets the Watchdog timer to the maximum timeout:
2^32 ticks / 3.125MHz = 1'374sec = 23min.
Return values
TRUE = success
FALSE = error
BOOL WatchdogRetrigger ( DWORD  Timeout_ms )
Retrigger Watchdog
Parameters
[in] Timeout_ms A hardware reset will be done if the Watchdog is not
retriggered within this time [ms]
valid range: 1...1'374'389
Return values
TRUE = success
FALSE = error
