Watchdog Software Library API
This article describes the Watchdog software library API and provides a functional overview
Defines
#define  WATCHDOG_VER_MAJ  1
Major Library Version.
#define  WATCHDOG_VER_MIN  0
Library Subversion.
#define  WATCHDOG_VER_BUILD  0
Library Build.
Functions
void  WatchdogGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
BOOL  WatchdogInit ()
BOOL  WatchdogDeinit ()
BOOL  WatchdogRetrigger (DWORD Timeout_ms)
Detailed Description
WatchDog Support Library.
Author:
kia, $Author$
Version:
$Rev$
Date:
$Date$
Target Platforms:
Colibri PXA320, Windows CE 6.0
Caveats:
The watchdog does not work on PXA270 due to bug in the PXA270 CPU.
Define Documentation
Library Build.
Library Subversion.
Function Documentation
BOOL WatchdogDeinit ( )
Deactivates watchdog This is not possible, therefore the function always returns FALSE
Return values:
TRUE success
FALSE error
void WatchdogGetLibVersion ( DWORD *  pVerMaj,
DWORD *  pVerMin,
DWORD *  pBuild
returns the version of this library
Parameters:
[out] pVerMaj Main Version of this library
[out] pVerMin Subversion of this library
[out] pBuild Build Number of this library
BOOL WatchdogInit ( )
Activates the watchdog, and sets the Watchdog timer to the maximum timeout: 2^32 ticks / 3.125MHz = 1'374sec = 23min.
Return values:
TRUE success
FALSE error
BOOL WatchdogRetrigger ( DWORD  Timeout_ms )
Retriggers Watchdog
Parameters:
[in] Timeout_ms A hardware reset will be done if the Watchdog is not retriggered within this time [ms]
valid range: 1...1'374'389
Return values:
TRUE success
FALSE error
