Windows CE Library - Analog-To-Digital Library (ADCLib)
Description
This library interfaces with the audio codec and the four analog-to-digital channels.
Current Version
V2.3
Application Notes
This library can identify the UCB1400, WM9713 and WM9715 codecs.
This library also provides for reading from the touch controller.
Access to library routines is controlled via a mutex with the identifier 'ACLINK_CONTROL'.
Library API
Other Resources
Windows CE Libraries Overview
How to use the ADC library
ADC Feature Comparison
WM9715 Codec
Audio driver registry settings
Revision History
Date Rev Change Notes
29/06/2015 V2.3 Fix initialization. The AdcLib is now working if it is uses before audio/touch initialization.
30/10/2014 V2.2 Support new driver concept for T20/T30 modules (required for WinCe image V1.3beta3 and higher)
Support ADC converter of Colibri T30 and Apalis T30.
23/09/2013 V2.1.2 Change default SDK to Colibri600
24/06/2013 V2.1.1 Added support for Colibri PXA300XT
