Windows CE Library - CANLib-SJA1000
Description
This library interfaces to the SJA1000 Stand-Alone CAN Controller.
Current Version
V3.3.2
Application Notes
CANLib-SJA1000 interfaces to a SJA1000 Stand-Alone CAN controller via a parallel bus interface.
The SJA1000 is located on the carrier board hosting the module running the library.
The Colibri Evaluation Board V2.1 contains an instance of this chip.
The library supports one instance of the interface on TXX modules and up to eight instances on PXAxxx modules.
Library API
The library API can be viewed here.
Other Resources
Windows CE Libraries Overview
Data Sheet
Revision History
Date Rev Change Notes
23/09/2013 V3.3.2 Change default SDK to Colibri600
12/08/2013 V3.3.1 Added support for T30
17/06/2013 V3.3.0 Added CANReInitialise() to DLL Definition File
