Windows CE Library - DMA Library (DMALib)
Description
This library manages DMA handling, including channel allocation and DMA transfer control on PXAxxx processors
Current Version
V1.3.1
Application Notes
This library supports up to 32 channels on PXAxxx processors.
The library uses a Mutex ('DMA_MUTEX') to protect against multiple access.
Library API
Other Resources
Windows CE Libraries Overview
DMA Channel Assignment
Revision History
Date Rev Change Notes
23/09/2013 V1.3.1 Change default SDK to Colibri600
