Windows CE Library - I2C Library - (I2CLib)
Description
This library manages communications via the I2C interfaces.
Current Version
V4.4
Application Notes
This library supports 100KBPS and 400KBPS.
This library uses a mutex called 'I2C' to control against simultaneous access.
Currently, this library supports only one I2C instance at a time.
Revision History
Date Rev Change Notes
29/06/2015 V4.4 Add support for non-DWORD-aligned receive buffer (Tegra only)
Prevent possible application hang (add timeout) when i2c signals were floating low.
30/10/2014 V4.3 Add support for all i2c channels on T20 and T30.
09/07/2014 V4.2 Fix i2c protocol in I2CBurstRead() for T20 and T30:
Do not send STOP condition after transmitting the offset value.
15/04/2014 V4.1.1 Internally mask slave address for the range 0..127
11/03/2014 V4.1 Fixed missing deinit of a variable for the T20/T30 modules in the I2CDeInit() function
Added more error checks
Library API
I2C Lib API
Other Resources
Windows CE Libraries and Code Samples
How to use I2C library
I2C (Colibri)
