Windows CE Library - Interrupt Service Routine Library (INTLib)
Description
This library manages installable Interrupt Service Routines.
Current Version
V2.6
Application Notes
INTLib provides for level-triggered and edge triggered interrupts.
Library API
Other Resources
Windows CE Libraries Overview
How to use Interrupt Library
Interrupt Sources
Interrupt Latency
Colibri T20 Interrupts
Revision History
Date Rev Change Notes
29/06/2015 V2.6 Fix memory leak in InterruptInitializeCompat() for Tegra
23/09/2013 V2.5.1 Minor Code optimizations
23/09/2013 V2.4 Change default SDK to Colibri600 / Replace OAL_INTR_FORCE_STATIC by OAL_INTR_TRANSLATE and added some fixes to allow reusing the same SysIntr IDs.
12/08/2013 V2.3.2 Changed scope of internal variables to be internal only
24/06/2013 V2.3.1 Fixed __GetUserKData() link error under Windows CE 5
