Windows CE Library - Map Register Library - (MapRegLib)
Description
This library provides for the mapping of physical registers to virtual addresses.
Current Version
V1.3
Application Notes
MapRegLib can be used to map physical registers and memory into the virtual address space of a Win CE application.
MapRegLib can also be used to allocate and free memory for use as buffers, etc to be used with DMA access to peripherals.
Library API
Other Resources
Windows CE Libraries Overview
Register Access
HW registers
Revision History
Date Rev Change Notes
27/05/2014 V1.3 VirtualSetAttributesCompat(): Add support for Tegra, but only for BSP V1.3beta2 and later
11/03/2014 V1.2 Fix: AllocPhysMemCompat() did not work on old T20/T30 images
17/06/2013 V1.1.1 Updated to work with Apalis T30
