Windows CE Library - Peripheral Clocks Library (CLKLib)
Description
This library manages peripheral clock settings.
Current Version
V3.3
Application Notes
On PXAxxx processors, each clock can simply be enabled or disabled.
On Txx processors, the library can select the correct clock source and divisor to either provide the closest frequency to that specified or to select the lowest power-consumption oscillator giving a frequency within a specified range.
CLKLib also contains a function to provide for blocking delays with a 1uS resolution.
Library API
Other Resources
Windows CE Libraries Overview
Revision History
Date Rev Change Notes
11/03/2014 V3.3 Prevent using non-constant clock sources PLLC and PLLM in function ClkLibSetClockFrequency()
23/09/2013 V3.2 Change default SDK to Colibri600 / Extend T30 support
