Windows CE Library - Update Library (UpdateLib)
Description
This library manages the programming of Image/Bootloader/Registry in on-board flash.
Current Version
V1.10
Application Notes
UpdateLib provides full support for Backup and Update on Colibri PXAxxx modules.
UpdateLib currently only provides Update support on Tegra modules.
Library API
Other Resources
Windows CE Libraries Overview
Update Tool
Production Programming (Tegra Modules)
Revision History
Date Rev Change Notes
29/06/2015 V1.10 Adjust the default file name when backing up
When flashing a splash screen, configure config block settings "oep" and "dispondelay"
Implement workaround for Kernel bug in Colibri PXAxxx BSP V4.4
30/10/2014 V1.8 Support new Spansion Flash
Support 1:1 Backup/Restore for Bootloader and image on Tegra modules
15/04/2014 V1.7 Implement Bootloader Update for T30
11/03/2014 V1.5 Fixes in clear registry part
Improved error reporting
Modified UDLReboot to prevent system freezes when shutting down the system.
23/09/2013 V1.4 Change default SDK to Colibri600 / Added support for Wiping the FlashDisk
12/08/2013 V1.3.3 Fixed issue with ClearRegistry() on Tegra on CE6/7
