WL250N USB WiFi Configurations
WiFi Channel Selection
Not all versions of the WL250N USB WiFi stick support all 14 WiFi channels. Visit the WL250N USB WiFi product website for details.
The drivers for the WL250N USB WiFi stick allow users to select the WiFi channels which can be used. The allowed WiFi channels are different for every country. Please make sure you comply with the laws of the country where you are using this USB stick. E.g. North America allows channels 1-11, most European countries allow channels 1-13 and Japan allows 1-14.
The "Country Region" setting is used for the configuration. The following settings are possible:
CountryRegion    Channel(s)
0                 1 - 11
1                 1 - 13
2                10 - 11
3                10 - 13
4                14
5                 1 - 14
6                 3 -  9
7                 5 - 13
Settings under Windows CE/Windows Embedded Compact
[HKEY_LOCAL_MACHINE\Comm\RT28701\Parms]
"CountryRegion"=dword:00000005
