Apalis iMX6 Mezzanine
Getting Started
This board is an add-on board for the Apalis Evaluation Board. This Mezzanine Board provides access to the type-specific interfaces on the Apalis iMX6 module. It makes the Apalis Evaluation Board compatible to the CSI Camera Module 5MP OV5640.
These interfaces may differ between different Apalis modules. Different type-specific mezzanine boards will be available for each Apalis module.
Customers are free to develop their own type-specific mezzanine board for prototyping and development purposes.
Please refer to the datasheets for the individual Apalis module for more information.
The Apalis iMX6 Mezzanine should be added to the order if you are planning to order the following composition of components:
Having trouble?
Please contact our technical support. Various technical support options are mentioned in the article below.
Features
Main Features
- 1x MIPI CSI-2 (Quad Lane)
- 1x MIPI DSI (Dual Lane)
- 1x Generic Header
- Media Local Bus (MediaLB) Interface
- Additional type-specific (TS_XX) signals
- Power pins
- 1x USB 2.0
- 1x Tactile switch to enter Apalis iMX6 module recovery mode
- 1x Tactile switch to reset Apalis iMX6 module
Datasheets
Apalis iMX6 Mezzanine V2.0 Datasheet
Apalis iMX6 Mezzanine Datasheet
Apalis iMX6 Mezzanine Datasheet Archive
Design Resources
Design data Apalis iMX6 Mezzanine V2.0
- Apalis iMX6 Mezzanine Altium Project (Altium Designer Release 10)
- Apalis iMX6 Mezzanine PDF Schematics
- Apalis iMX6 Mezzanine Assembly Drawing
- Apalis iMX6 Mezzanine Bill of Materials (BOM)
Design data Apalis iMX6 Mezzanine Archive
Altium Designer
Compatible Products
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0117xxxx - Apalis iMX6 Mezzanine
| Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
| 01171000 | Apalis iMX6 Mezzanine V1.0A | Initial Release | 2015-04-15 | PCN Apalis iMX6 Mezzanine V1.0A 2018-04-30 |
| 01172000 | Apalis iMX6 Mezzanine V2.0A | Made compatible with the Toradex CSI Camera Module | 2018-04-30 |
Errata
None
