Colibri Evaluation BoardContents[hide]Welcome to the product page for the Colibri Evaluation Board.
This page contains a variety of information relating to the Colibri Evaluation Board product and is intended to be used as a single point of access for all information you need. Getting StartedIf you are new to the Colibri family of computer on modules, this section is intended to help get you up and running fast. What do I need to order?The Colibri Evaluation Board does not come supplied with a Colibri module. you will need to purchase this seperately. To determine which module is most suitable for your application, please review the modules and their individual specifications here. All Colibri modules are compatible with the Colibri Evaluation Board. Do I need anything else in addition?The following list details other equipement that is either required or optional to get up and running Required
Optional
Where do I buy this product?Toradex distributes directly to customers, exclusively via the internet. To place your order, please use our webshop. Starting the system for the first timePlease watch our quick start tutorial. Having trouble?If you are having trouble getting started, then our support team is here to help you. Please follow these steps to contact the support. Further informationFor further information, please refer to the product documentation for the Colibri module which you are using with the Colibri Evaluation Board. Main FeaturesFeatures of the Colibri Evaluation Board are given below. Supported Colibri Modules
Features and Interfaces
DatasheetsProduct Datasheet: Design Guides and Application NotesDesign data Colibri Evaluation Board V3.1:
Design data Colibri Evaluation Board V2.1: The Migration Guide contains the needed steps to switch between the several Toradex Colibri modules. Software DownloadsPlease see the product documentation for the Colibri module you are using for more information. The Evaluation Board includes a CAN controller. Toradex provides Software libraries which support the CAN functionality on the Evaluation board. You can find more information about the supported SW features here or contact our support. Knowledge BaseTo show all articles applicable to the Colibri Evaluation Board, please click the following link: Related ProductsCompatible Products and Accessories
Other Related ProductsProduct Revision HistoryProduct revision history for the Colibri Evaluation Board.
