Colibri iMX6
Colibri iMX6S
Colibri iMX6S - Back
Colibri iMX6DL
Colibri iMX6DL - Back
(Double-Click to Zoom)
The Colibri iMX6 is a Toradex System on Module based on the NXP i.MX 6 SoC, and a member of the Colibri Family.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Colibri iMX6 module.
Getting Started
Recommendation for the First-Time Order
Quickstart Guide
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Having trouble?
Product Features
Hardware Features
Compatible Products
Pinout Evaluation & Planning
Power Consumption
Product Documents
Datasheets
Colibri iMX6 V1.2
Design Resources
Toradex provides two different 3D models for Colibri Systems on Module:
  • Generic Colibri 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
  • Specific Colibri 3D Mechanical Models: These models are simplified models of the respective Colibri module. They contain only the PCB and the CPU and are intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different.
The generic Colibri 3D model contains the PCB and the maximum component height on top and bottom of modules from the Colibri Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Colibri modules as well as future releases.
Colibri iMX6 - Specific 3D Mechanical Models
The Colibri iMX6 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic Colibri 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
Design and Layout Guide
Hardware Ecosystem
Carrier Boards
Off-the-shelf Carrier Boards
Custom Carrier Board Design
Find free reference designs, schematics, 3D designs, and tools to build your carrier board easily in the link below:
Accessories & Add-ons
Check other options and compatibility information on the add-ons product pages.
Software Ecosystem
Toradex-Supported Windows Embedded Compact (EOL)
Torizon OS with containers has limited performance on the Colibri iMX6. Toradex recommends using the Torizon OS Yocto Reference Minimal Image for such scenarios.
Windows CE is EOL. Refer to WinEC Affected Modules EOL - Migration Guide for more information.
Development Resources
Connecting to the Board
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0014 Colibri iMX6S 256MB (WinEC)
Product #Product DescriptionChanges from Previous VersionRelease DatePre-Installed SoftwareRelated Documents
00141000
Colibri iMX6S 256MB V1.0A
  • Initial Release
Q4 2014
PCN Colibri iMX6S 256MB V1.0A 2017-06-14
00141100
Colibri iMX6S 256MB V1.1A
  • Replacing eMMC Toshiba THGBMBG5D1KBAIT (EOL) with Micron MTFC4GACAJCN-1M-WT
  • i.MX 6 SoC and eMMC are irrevocably configured (fused) for “fast boot mode"
  • The pre-installed software changes from “embedded Linux" to “Toradex Easy Installer"
  • Resolved start-up issue when VBATT is supplied and the module was shut-down by software
  • Resolved microphone lock-up issue when plugging-in microphones
  • nRESET_OUT (SODIMM pin 87) can now be toggled through software
  • Improved internal reset timing for Micrel Ethernet PHY
  • Changed internal eMMC IO voltage from 3.3V to 1.8V
  • Added JTAG_MOD feature to SODIMM pin 180
  • Added support for SD UHS-I 1.8V IO mode
2017-06-14
ToradexEasyInstaller_1.8-20181019
TPIN Colibri iMX6 V1.1Z 2021-04-15
PCN Colibri iMX6S 256MB V1.1A 2021-11-25
00141101
Colibri iMX6S 256MB V1.1B
  • Replacing eMMC: Micron MTFC4GACAJCN-1M WT with SkyHigh S40FC004C1B1C00
Q2, 2022
ToradexEasyInstaller_5.3
EOL PCN Colibri iMX6S 256MB
00141125
Colibri iMX6S 256MB V1.1Z
  • Additional version with limited features, sold on request only
  • Removed STMPE811QTR touch/ADC controller and related components due to temporary component shortage
Q2 2021
Software Adjustments for Colibri / Apalis iMX6 V1.1Z Modules
TPIN Colibri iMX6 V1.1Z 2021-04-15PCN Colibri iMX6S 256MB V1.1Z 2021-11-25
00141124
Colibri iMX6S 256MB V1.1Y
  • Additional version with limited features, replaces V1.1Z
  • Replacing eMMC: Micron MTFC4GACAJCN-1M WT with SkyHigh S40FC004C1B1C00 (new change in V1.1Y)
Q2 2022
Software Adjustments for Colibri / Apalis iMX6 V1.1 Z and Y Modules
PCN Colibri iMX6 Temporary versions EOL 2024-03-14
0016 Colibri iMX6S 256MB IT (WinEC)
00161000
Colibri iMX6S 256MB IT V1.0A
  • Initial Release
Q4 2014Sample Product, No PCN
00161001
Colibri iMX6S 256MB IT V1.0B
  • eMMC is changed
Q1 2015
PCN Colibri iMX6S 256MB IT V1.0B 2017-05-02
00161100
Colibri iMX6S 256MB IT V1.1A
  • Replacing eMMC 4GB Toshiba THGBMAG5A1JBAWR (EOL) with 4GB Micron MTFC4GACAJCN-4M-IT
  • i.MX 6 SoC and eMMC are irrevocably configured (fused) for “fast boot mode" in the new version
  • Changed internal eMMC voltage from 3.3V to 1.8V
  • Added option to use SD UHS-I 1.8V mode
2017.05.30
PCN Colibri iMX6S 256MB IT V1.1A 2021-11-25
00161101
Colibri iMX6S 256MB IT V1.1B
  • Replacing eMMC: Micron MTFC4GACAJCN-4M IT with a Macronix MX52LM04A11XUI
Q4 2021
TPIN Colibri iMX6S 256MB IT V1.1Y 2022-01-13
EOL PCN Colibri iMX6S 256MB IT
00161125
Colibri iMX6S 256MB IT V1.1Z
Q2 2021
Software Adjustments for Colibri / Apalis iMX6 V1.1Z and Y Modules
PCN Colibri iMX6S 256MB IT V1.1Z 2022-01-13
00161124
  • Removed STMPE811QTR touch/ADC controller and related components due to temporary component shortage (was already implemented in V1.1Z)
  • Replacing eMMC: Micron MTFC4GACAJCN-4M IT with a Macronix MX52LM04A11XUI (new change in V1.1Y)
Q1 2022
0015 Colibri iMX6DL 512MB (WinEC)
00151000
Colibri iMX6DL 512MB V1.0A
  • Initial Release
Q4 2014
PCN Colibri iMX6DL 512MB V1.0A 2017-05-02
00151100
Colibri iMX6DL 512MB V1.1A
  • Replacing eMMC 4GB Toshiba THGBMBG5D1KBAIT (EOL) with 4GB Micron MTFC4GACAJCN-1M-WT
2017-05-30
PCN Colibri iMX6DL 512MB V1.1A 2021-11-25
00151101
Colibri iMX6DL 512MB V1.1B
Q4 2021
EOL PCN Colibri iMX6DL 512MB
00151125
Colibri iMX6DL 512MB V1.1Z
Q2 2021
PCN Colibri iMX6 V1.1Z 2021-12-02
00151124
Colibri iMX6DL 512MB V1.1Y
Q1 2022
0017 Colibri iMX6DL 512MB IT (WinEC)
00171000
Colibri iMX6DL 512MB IT V1.0A
Initial Release
Q4 2014
00171001
Colibri iMX6DL 512MB IT V1.0B
  • eMMC is changed
Q1 2015
PCN Colibri iMX6DL 512MB IT V1.0B 2017-04-19
00171100
Colibri iMX6DL 512MB IT V1.1A
  • Replacing eMMC Toshiba THGBMAG5A1JBAWR (EOL) with Micron MTFC4GACAJCN-4M-IT
  • Changed i.MX6 SoC from MCIMX6U7CVM08AB to MCIMX6U7CVM08AC
2017-05-30
PCN Colibri iMX6DL 512MB IT V1.1A 2021-11-25
00171101
Colibri iMX6DL 512MB IT V1.1B
Q4 2021
EOL PCN Colibri iMX6DL 512MB IT
00171125
Colibri iMX6DL 512MB IT V1.1Z
Q2 2021
PCN Colibri iMX6DL 512MB IT V1.1Z 2021-11-25
00171124
Colibri iMX6DL 512MB IT V1.1Y
Q4 2021
0077 Colibri iMX6S 256MB
Product #Product DescriptionChanges from Previous VersionRelease DatePre-Installed SoftwarePCN Document
00771100
Initial Version
Module based on 00141101 without WinEC License
2024-04-01Toradex Easy Installer 5.7.5+build.19New Product Configurations Without WinEC
PCN Colibri IMX6 (non WinCE) V1.1 To V1.2 - 2025-12-12 (UPDATED 2026-01-09)
00771200
Colibri iMX6S 256MB V1.2A
New revision to replace STMPE811QTR due to EOL.
  • PCB changed from V1.1 to V1.2
  • Touch controller ST STMPE811QTR has been replaced with Analog Devices AD7879-1ACBZ-500R7
  • Texas Instruments TLA2024IRUGR has been added to the board
Q4-2026Toradex Easy Installer 5.7.5+build.19
0078 Colibri iMX6S 256MB IT
00781100
Initial Version
Module based on 00161101 without WinEC License
00781200
Colibri iMX6S 256MB IT V1.2A
0079 Colibri iMX6DL 512MB
00791100
Initial Version
Module based on 00151101 without WinEC License
00791200
Colibri iMX6DL 512MB V1.2A
0080 Colibri iMX6DL 512MB IT
00801100
Initial Version
Module based on 00171101 without WinEC License
00801200
Colibri iMX6DL 512MB IT V1.2A
Errata/Known Issues
SoC Errata Document
Filter by Errata on the:
SoM Errata Document
Hardware Issue Tracker
Software Issue Tracker
