Colibri T20
NVIDIA Tegra 2 Computer on Module - Colibri T20 - Front
NVIDIA Tegra 2 Computer on Module - Colibri T20 - Back
(Double-Click to Zoom)
warning
Colibri T20 is a discontinued (EOL) product, see "Revision History" for details. Toradex prepared a guide that helps customers using end-of-life (EOL) Tegra products migrate to recommended hardware and software solutions for their products. For more information, consult the Tegra Migration Guide.
Getting Started​
Colibri T20 is a member of the Colibri family. You will find all technical details such as features, datasheets, software, etc. here.
Not Recommended For New Designs: Given supply chain uncertainty with this product, we advise switching to another Toradex product.
For starting for the first time with your Colibri T20 you will need a suitable Colibri Carrier Board as well as some adapters and cables for connecting your desired interfaces.
Toradex recommends to order the following accessories for your fist-time order:
You can buy the Colibri T20 module, Colibri Evaluation Board and Carrier Board Accessory Kit from the Toradex webshop.
Getting started for the first time?​
For detailed step-by-step instructions about how to start using Embedded Linux, please have a look at our step-by-step Getting-Started Guide:
Additional information​
For information on how to update the module's Operating System, or change from Embedded Linux to Windows CE and vice-versa, please check the article below:
We also have quick video tutorials on our Youtube Channel:
For developing software on the platform, please browse through the list of knowledge-base articles provided in the link below:
Having trouble?​
Features​
Processor​
  • NVIDIA Tegra 2 dual-core Cortex-A9
  • 1.0 GHz operational frequency
  • L1 Instruction Cache(each core) = 32KB
  • L1 Data Cache(each core) = 32KB
  • L2 Cache(shared by cores) = 1MB
  • VFPv3-D16 Floating Point Unit (Double Precision)
Memory​
  • 256MB/512MB DDR2 (32 Bit) RAM
  • 512MB/1GB NAND Flash (8 Bit) Flash
Interfaces​
  • 32 Bit Data Bus
  • USB (1x Host, 1x OTG)
  • I2C (3x)
  • SPI (5x)
  • One-wire (1x)
  • UART (5x)
  • IrDA (1x)
  • PWM (4x)
  • Up to 153 GPIOs
  • Analog Input (4x 12 Bit)
  • Ethernet (1x 10/100 Mbit)
  • SDIO/SD/MMC (4x 8 Bit)
  • S/PDIF (1x)
  • HDMI (V1.3 1080p)
  • VGA (1600x1200)
  • RGB (1920x1200x24bpp)
  • Resistive Touch (4/5-wire)
  • Camera Parallel Interface (1x)
  • Analog Audio Line in (1x, Stereo)
  • Analog Audio Mic in (1x, Mono)
  • Analog Audio Headphone out (1x, Stereo)
Supported operating systems​
Datasheets​
Module's Datasheet​
Colibri T20 Datasheet
Additional Resources​
Software​
Get details including free downloads of images and BSPs for operating systems supported by Colibri T20.
3D Models​
Toradex provides the following 3D models for this Colibri System on Module:
  • Generic Colibri 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
Generic Colibri 3D Mechanical Models​
The generic Colibri 3D model contains the PCB and the maximum component height on top and bottom of modules from the Colibri Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Colibri modules as well as future releases.
Carrier Boards​
Off-the-shelf Carrier Boards​
From Toradex​
From Partners​
Custom Carrier Board Design​
Find free reference designs, schematics, 3D designs and tools to build your carrier board easily in the link below.
Accessories​
Revision History​
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0020 Colibri T20 256MB​
00201101
Colibri T20 256MB V1.1B
Initial Release
2011
PCN Colibri T20 256MB V1.1B 2012-02-24
00201200
Colibri T20 256MB V1.2A
New Flash Type
New PMIC Type
2012-02-24
Pre-installed software change:Β PCN Colibri T20 256MB V1.2A 2016-05-05
This product has an end-of-life notice (EOL), see PCN:
PCN (EOL) Colibri T20 256MB V1.2A 2022-12-20
Introducing a new version to increase availablity:Β PCN Colibri T20 256MB V1.2A 2024-02-09
00201201
Colibri T20 256MB V1.2B
  • Replacing NAND: Micron MT29F4G08ABBEAH4-IT:E with Micron MT29F4G08ABBFAH4-IT:F
  • Replace capacitor C157: 10uF capacitor used for the touch/ADC reference with 1uF
2024-02-09
  • This version has been introduced due to NAND supply issues. Please, note that group EOL still applies.
0024 Colibri T20 256MB IT​
00241200
Colibri T20 256MB ITΒ V1.2A
Initial Release
2012-05-23
PCN Colibri T20 256MB IT V1.2A 2016-05-05
PCN Colibri T20 256MB IT V1.2A 2022-02-03
00241201
Colibri T20 256MB ITΒ V1.2B
Internal version
00241202
Colibri T20 256MB ITΒ V1.2C
Q1, 2022
PCN (EOL) Colibri T20 256MB IT V1.2C 2022-12-20
0021 Colibri T20 512MB​
00201102
Colibri T20 512MB V1.1C
Initial Release
2011
PCN Colibri T20 512MB V1.1C 2012-02-24
00211200
Colibri T20 512MB V1.2A
New Flash Type
New PMIC Type
2012-02-24
Pre-installed software change:Β  PCN Colibri T20 512MB V1.2A 2016-05-05
PCN Colibri T20 512MB V1.2A 2022-02-03
00211201
Colibri T20 512MB V1.2B
  • Replacing RAM: IM IM2G16D2DBBG-25 with Micron MT47H128M16RT-25E:C
  • Replacing capacitor C157: 10uF capacitor used for the touch/ADC reference with 1uF
Q1, 2022
PCN (EOL) Colibri T20 512MB V1.2B 2022-12-20
0022 Colibri T20 512MB IT​
00221200
Colibri T20 512MB ITΒ V1.2A
Initial Release
2011-04-15
Pre-installed software change:Β  PCN Colibri T20 512MB IT V1.2A 2016-05-05
PCN (EOL) Colibri T20 512MB IT V1.2A 2022-12-20
Errata/Known issues​
SoC Errata​
Specific SoC errata documents are not easily available, due to this being a mature offering by NVIDIA. You can browse the pages below for some information:
Software Issue Tracker - Colibri T20​
WinCE
