Colibri T30
Colibri T30 is a discontinued (EOL) product, see "Revision History" for details. Toradex prepared a guide that helps customers using end-of-life (EOL) Tegra products migrate to recommended hardware and software solutions for their products. For more information, consult the Tegra Migration Guide.
Getting Started
Colibri T30 is a member of the Colibri family. You will find all technical details such as features, datasheets, software, etc. here.
Recommendation for a first-time order (Not Recommended For New Designs)
Not Recommended For New Designs: Given supply chain uncertainty with this product, we advise switching to another Toradex product.
For starting for the first time with your Colibri T30 you will need a suitable Colibri Carrier Board as well as some adapters
and cables for connecting your desired interfaces.
Toradex recommends to order the following accessories for your fist-time order:
Colibri Evaluation Board: For an easy evaluation of Colibri interfaces.
Carrier Board Accessory Kit: Including suitable cables, adapters and a power supply.
You can buy the Colibri T30 module, Colibri Evaluation Board and Carrier Board Accessory Kit from the Toradex webshop.
Getting started for the first time?
For detailed step-by-step instructions about how to start using Embedded Linux, please have a look at our step-by-step Getting-Started Guide:
Additional information
For information on how to update the module's Operating System, or change from Embedded Linux to Windows CE and vice-versa, please check the article below:
We also have quick video tutorials on our Youtube Channel:
For developing software on the platform, please browse through the list of knowledge-base articles provided in the link below:
Having trouble?
Please contact our technical support. Various option of technical support are mentioned below.
Features
Processor
- NVIDIA Tegra 3 quad-core Cortex-A9
- Up to 1.4GHz operational frequency
- L1 Instruction Cache per core = 32KB
- L1 Data Cache per core = 32KB
- L2 cache shared among cores = 1MB
- VFP Vector Floating Point Unit (Double Precision)
- NEON single instruction multiple data (SIMD) instruction set extension
Memory
- 1GB DDR3L RAM (32 Bit)
- 4GB eMMC Flash (8 Bit)
Interfaces
- 16-Bit External Bus
- USB (1x Host, 1x OTG)
- I2C (4x)
- SPI (6x)
- One-wire (1x)
- UART (5x)
- IrDA (1x)
- PWM (4x)
- Up to 158 GPIOs
- Analog Input (4x 12 Bit)
- Ethernet (1x 10/100 Mbit)
- SDIO/SD/MMC (3x 4 Bit)
- S/PDIF In/Out (1x/1x)
- HDMI (V1.4a 1080p)
- VGA (1920x1200)
- RGB (2048x1536x24bpp)
- Resistive Touch (4-wire)
- Camera Parallel Interface (1x)
- Analog Audio Line in (1x, Stereo)
- Analog Audio Mic in (1x, Mono)
- Analog Audio Headphone out (1x, Stereo)
Supported operating systems
In-house development and support
Supported by Partners
Datasheets
Module's Datasheet
Additional Resources
Software
Get details including free downloads of images and BSPs for operating systems supported by Colibri T30.
3D Models
Toradex provides the following 3D models for this Colibri System on Module:
Generic Colibri 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
The generic Colibri 3D model contains the PCB and the maximum component height on top and bottom of modules from the Colibri Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Colibri modules as well as future releases.
Carrier Boards
Off-the-shelf Carrier Boards
From Toradex
From Partners
Custom Carrier Board Design
Find free reference designs, schematics, 3D designs and tools to build your carrier board easily in the link below.
Accessories
- EDT Display
- Colibri Fastener
- Capacitive Touch Display 7" Parallel
- Resistive Touch Display 7" Parallel
- Carrier Board Accessory Kit
- Colibri HDMI Adapter
- LM816 USB WiFi
- Analogue Camera Adapter
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0023 Colibri T30 1GB
| Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
00231101 | Colibri T30 1GB V1.1B |
| 2013-03-15 | Sample Product, No PCN |
00231102 | Colibri T30 1GB V1.1C |
| 2013-04-13 | Sample Product, No PCN |
| 00231103 | Colibri T30 1GB V1.1D |
| 2014-04-11 | Sample Product, No PCN |
| 00231104 | Colibri T30 1GB V1.1E |
| 2014-10-15 | PCN Colibri T30 1GB V1.1E 2017-04-19 |
| 00231105 | Colibri T30 1GB V1.1F |
| 2017-05-31 | PCN Colibri T30 1GB V1.1F |
| 00231106 | Colibri T30 1GB V1.1G |
| 2022-02 | This product has an end-of-life notice (EOL), see PCN: |
| 00231123 | Colibri T30 1GB V1.1X |
| Q2/2023 | This product has an end-of-life notice (EOL) - Tegra T30 Product Change Notification Guide |
0030 Colibri T30 1GB IT
00301100 | Colibri T30 1GB IT V1.1A |
| 2015-07-15 | PCN Colibri T30 1GB IT V1.1A 2017-07-06 |
00301101 | Colibri T30 1GB IT V1.1B |
| 2017-07-06 | This product has an end-of-life notice (EOL), see PCN: |
| 00301123 | Colibri T30 1GB IT V1.1X |
Errata/Known issues
SoC Errata
Specific SoC errata documents are not easily available, due to this being a mature offering by NVIDIA. You can browse the pages below for some information:
- Tegra Hardware Information - includes Technical Reference Manuals.
- Linux For Tegra R16 - the last release for Tegra 2 and 3.
SoM Errata Documents
Hardware Errata/Known Issues
Issue trackers are not yet available in the new developer website. See it on the archived developer website.
