Iris Carrier Board
Iris Carrier Board
Iris Carrier Board
(Double-Click to Zoom)
The Iris Carrier Board is a carrier board that gives you easy access to a selected set of the interfaces of the Colibri System on Modules (SoMs), intended as a production platform.
Pair the Iris Carrier Board with your choice of Colibri System on Module (SoM) for a validated, production-ready Single-Board Computer (SBC), available in volume with long-term availability and support. The board and module are supplied separately for you to assemble.
For a custom version, Toradex Solutions can populate fewer features on the same PCB or design a new board based on it.
Free design resources also let you customize the board yourself, starting from a validated, supported design.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Colibri SoM family.
Getting Started​
Recommendation for the First-Time Order​
Quickstart Guide​
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Product-specific information for the Iris Carrier Board:
Having trouble?​
Product Features​
Hardware Features​
Components​
Compatible Products​
Accessories & Add-ons​
[1] Capacitive Touch Adapter is required for Iris V1.1A and V1.1B, but is not required for V2.0 onwards.
[2] The LVDS cable that comes with the Capacitive Touch Display 10.1" LVDS is only compatible with Iris V2.0 onward. The LVDS signal on Iris is provided through an RGB to LVDS transmitter.
Check other options and compatibility information on the add-ons product pages.
Block Diagram​
* This is a module-specific feature and may not be supported by all the computer-on-modules in the Colibri family. For more details, refer to the datasheet of Colibri computer-on-modules.
Pinout Evaluation & Planning​
Product Documents​
Datasheets​
Iris Carrier Board V2.0
Iris Carrier Board V1.1
Design Resources​
Iris Carrier Board Design Data V2.0
Iris Carrier Board Design Data V1.1
Please also have a look at the Iris Carrier Board Errata Document.
Iris Carrier Board Mechanical Models​
A basic 3D model for the Iris carrier board can be downloaded here:
Design and Layout Guide​
Altium Designer​
Software Ecosystem​
Toradex-Supported Linux Platforms​
Industry and Partner Software Ecosystem​
Development Resources​
Installing the Operating System​
Connecting to the Board​
Applying Settings for your Hardware Combination​
With the terminal connection to the board, select the appropriate Device Tree for your board and reboot the device. This is the main configuration needed to match your SoM to the carrier board.
# sudo fw_setenv fdtfile <som-designation>-<wifi/nonwifi>-<carrier-board-designation>.dtb
The placeholders identify the SoM, Wi-Fi variant (where applicable), and carrier board. The exact naming varies by module family.
Example for Colibri iMX6 DualLite on the Iris Carrier Board V2:
# sudo fw_setenv fdtfile imx6dl-colibri-iris-v2.dtb
Refer to Device Trees on Toradex System on Modules to find the device tree for your SoM and carrier board combination. Use the corresponding .dts filename with the extension changed to .dtb.
Revision History​
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0135 Iris Carrier Board​
01351000
Iris Carrier Board- V1.0A
Sample Version
2011-04-05
Sample Product, No PCN
01351100
Iris Carrier Board- V1.1A
Volume Production Version
2011-07-20
PCN Iris V1.1A 2017-06-20
01351101
Iris Carrier Board V1.1B
Change of micro SD card holder
July 2017
PCN Iris V1.1B 2019-12-12
Update:
PCN Iris V1.1B 2021-07-21
01352000
Iris Carrier Board V2.0A
  • Major updates on: Power Supply, Ethernet, USB, Micro SD, Display interfaces, LVDS, Audio, RTC and Battery holder, see PCN document for Iris V1.1B for details
  • SHIELD/CHASSIS_GND signal connection to mounting holes and connectors body (like USB, Ethernet, DVI) have been improved for better EMC behavior.
  • Iris is now fully Industrial Temperature grade
2019-12-12PCN Iris V2.0A 2023-03-28
01352001
Iris Carrier Board V2.0B
  • Reduced USB_C_DET backfeeding current by a factor of 10: Changed R115 from 560R to 10k and R116 from 1k to 10k (details: HAR-8293)
  • Resolved RS232 transceiver backfeeding issue: Changed TI SN65C3243 with TI MAX3243IDBR (details: HAR-8294)
  • Resolve USB power switching backfeeding: Removed R156 and assembled R157 (details: HAR-8292)
Q2/2023
Errata/Known Issues​
Errata Document​
Hardware Issue Tracker​
