Viola Carrier Board
Getting Started
Viola is the smallest off-the-shelf carrier board and is compatible with the entire Colibri product family. Carefully selected features packed in a small form factor makes the Viola carrier board suitable for a wide range of embedded applications. The Viola carrier board is an ideal choice to create low cost embedded solutions. Viola carrier board is designed keeping production environment in mind. For evaluation and development purpose, customers are advised to use Colibri Evaluation Board or Iris Carrier Board.
The Viola V1.2 carrier board will be available in two assembly variants:
- Viola
- Viola Plus
Viola is not the best option for development. We recommend that you buy, in addition to Viola, another carrier board for your development team, and use Viola in production.
This section contains initial information needed to set-up the Viola Carrier Board for the first time.
Toradex recommends to order the following additional products for your fist-time order:
Getting started for the first time?
The step-by-step Getting-Started guide is not available for Viola Carrier Board, as Toradex does not recommend it for first steps or development purposes.
Product-specific information for the Viola Carrier Board:
Having trouble?
Features
I/O Support
The table below list down the main features available on the Viola V1.2 and Viola Plus V1.2 Carrier Boards.
✓ : Assembled by default.
✖ : Not Assembled.
Features | Viola V1.2 | Viola Plus V1.2 |
Ethernet Connector (X5) | ✓ | ✓ |
2x USB Host (X6, Dual Stacked Type-A) | ✓ | ✓ |
USB Client (X4, Micro-AB Type) | ✖ | ✓ |
Micro SD Card Connector (X8) | ✓ | ✓ |
Unified Interface Display (X7) | ✓ | ✓ |
Extension Connector (X9)
Audio Connector (X10)
Colibri VFxx Tamper Connector (X11) | ✖ | ✖ |
Terminal Block Power Supply Connector (X3) | ✓ | ✓ |
Barrel Power Supply Connector (X2) | ✖ | ✓ |
Battery Holder (BAT1) | ✓ | ✓ |
External RTC | ✖ | ✓ |
LED Indication (3.3V Power) | ✓ | ✓ |
- CAN: This is module specific feature and may not be supported on all the modules in Colibri Family. Please refer
Colibri module datasheets for more details.
- Parallel Camera Interface (CIF) signals are connected to the connectors X9 and X10.
Block Diagram
* Please note that these features are module-specific and may not be supported by all the computer-on-modules in the Colibri family. For more details, refer to the datasheet of Colibri computer-on-modules.
Datasheets
Viola Carrier Board V1.2
Viola Carrier Board V1.2 Datasheet
Viola Carrier Board V1.1
Viola Carrier Board V1.1 Datasheet
Viola Carrier Board V1.0
Viola Carrier Board V1.0 Datasheet
Components
Design Resources
Design data Viola Carrier Board V1.2
- Viola Altium Project (Altium Designer Release 10)
- Viola PDF Schematics
- Viola Assembly Drawing
- Viola Bill of Materials (BOM)
Design data Viola Plus Carrier Board V1.2
Design data Viola Carrier Board Archive
- Viola Board Schematics
- Viola Assembly Drawings
- Viola Board Bill of Materials (BOM)
Viola Carrier Board Mechanical Models
Viola Plus
A basic 3D model for the Viola Plus Carrier Board can be downloaded here:
Viola
3D CAD model for previous versions of the Viola Carrier Board can be downloaded from the archive:
Altium Designer
Compatible Products
- Colibri iMX8X
- Colibri iMX7
- Colibri iMX6
- Colibri iMX6ULL
- Colibri VF61
- Colibri VF50
- Colibri T30
- Colibri T20
- Colibri PXA320
- Colibri PXA310
- Colibri PXA270
- EDT Display
- Carrier Board Accessory Kit
- Capacitive Touch Display 7" Parallel [1]
- Resistive Touch Display 7" Parallel
- LM816 USB WiFi
- Analogue Camera Adapter
[1] Capacitive Touch Adapter is required.
Revision History
Product Number (PID8) Format
Field | Description |
PPPP | 4-digits number, indicating the Product Configuration (PID4) that describes the key properties of the product (e.g. Product Group, RAM capacity, etc.) |
VV | 2-digits number, indicating the Major and Minor Version (in that order) |
AA | 2-digits number, indicating the Assembly Variant |
Example
0029: Apalis iMX6D 512MB11: Major Version 1, Minor Version 1, Version V1.1 in short
00: Assembly Variant A
Viola Carrier Board
PN: 0137
Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
01371000 | Viola Carrier Board V1.0A | Sample Version | 2014-07-01 | Sample Product, No PCN |
01371100 | Viola Carrier Board V1.1A | Rearranged GPIO/PWM signals on Connector X9 USB Client assembly option added, etc. | 2014-09-05 | PCN Viola Carrier Board V1.1A 2015-01-08 |
01371200 | Viola Carrier Board V1.2A | See Viola Comparison article for details | Q3/Q4 2015 | PCN Viola Carrier Board V1.2A 2017-12-20 |
01371201 | Viola Carrier Board V1.2B | Fixed battery errata | 2017-12-20 |
PN: 0142
01421200 | Viola Plus Carrier Board V1.2A | See Viola Comparison article for details | Q3/Q4 2015 | PCN Viola Carrier Board V1.2A 2017-07-10 |
01421201 | Viola Plus Carrier Board V1.2B | Solving battery holder issue of Errata #1. | July 2017 |
