Search by Tags
WEC PXA BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the PXA Windows CE BSPs and images.
Clear Filter
Not Planned
WC-1265Known IssueDelayed Serial Transmit CompletionColibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300UARTCE5, CE6
Description: The serial transmit thread can be interrupted by a thread with the same interrupt priority. This could lead to delayed transmit completion. This normally only affects customers which are using e.g. a RTS toggle function for RS-485 communication as the RTS signal may take several 10ms until it toggles back after sending data.
Workaround: Increase the priority of the sending thread.
