Search by Tags
WEC PXA BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the PXA Windows CE BSPs and images.
Clear Filter
V4.4 (Release date: 2015-04-14)
- WinCE 5 Updates: Installed Microsoft CE5 Updates until 2014M07
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2014M07
WC-1263FixedImprove ConfigBlock concept and use a second copy of it in order to avoid config lossColibri PXA320, Colibri PXA310, Colibri PXA270, Colibri PXA300 XT, Colibri PXA300Bootloader, ConfigBlock, KernelCE5, CE6
Description: The config block could be lost if extensively used. This issue has only been seen at one customer so far and in special test-setups. We will use a second back-up copy of the config block in order to avoid the loss.
