Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V2.0beta2 (Release date: 2016-08-23)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M06
- WEC 2013 Updates: Installed Updates until 2016M06
To Upgrade to 2.0 beta 2 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-2056FixedApalis T30: Support Multiple PCIe ChannelsApalis T30PCIeWEC7, WEC2013
Description: Currently only one PCIe channel is supported. This channel is already used by the internal Ethernet interface on the Apalis module. Toradex has to modify the Microsoft PCI driver to add support for multiple PCIe devices at the same time.
Workaround: Disable the internal Ethernet Controller in order to use your own PCIe device.
