Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V2.0beta1 (Release date: 2016-05-17)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M03
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M03
- WEC 2013 Updates: Installed Updates until 2016M03
To Upgrade to 2.0 beta 1 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1515FixedPrevent reconfiguration of Serial PinsColibri T20, Colibri T30, Apalis T30UARTCE6, WEC7, WEC2013
Description: Pins of the serial port are reconfigured with every open and close of the serial port. This is an issue for customer using some UART pins as GPIO Pin. To solve this issue set up a PinMux configuration (Registry key PinMuxConfig) that matches your requirements: See all possible configurations here: http://developer.toradex.com/knowledge-base/serial-ports
