Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V2.0beta2 (Release date: 2016-08-23)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M06
- WEC 2013 Updates: Installed Updates until 2016M06
To Upgrade to 2.0 beta 2 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1576FixedRare file corruption when writing to flashdisk or SDColibri T30, Apalis T30Flash, SDIO/SD/MMCWEC7, WEC2013
Description: Writing files to the flash disk or SD memory device in rare cases corrupted files.
Workaround: Disable L2 Cache in bootloader (pex.l2enable=0).
