Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
Not Planned
WC-1564Known IssueException in Thumb mode causes System Freeze on CE7Colibri T20, Colibri T30, Apalis T30WEC7
Description: The CE7 exception handler seems to have a problem if the exception happens in thumb mode (instead of the normal arm32 mode). This also happens if not explicitly using Thumb mode. This is an issue if the exception handling is triggered by any uninitialized function pointer with an odd value.
Workaround: None. This is a Microsoft code issue. Microsoft is aware of it but currently doesn't plan to fix it.
