Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V2.0beta4 (Release date: 2017-01-04)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M10
-WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M09
- WEC 2013 Updates: Installed Updates until 2016M11
To Upgrade to 2.0 beta 4 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-2139New FeatureMultiplexed pins are not tristated on T30 modulesColibri T30, Apalis T30WEC7, WEC2013
Description: There are some pins on the Colibri / Apalis T30 module which have multiple signals multiplexed on it. The following pins are tristeded in the Bootloader: 136, 138, 95 (GPIO 71 and 69). Configuration is done in the gpio.bootconf, see also issue 7823.
Workaround: Reconfigure the signals on these pins after boot-up through the GPIOLib or directly in the GPIO registers.
