Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
Not Planned
WC-1856Known IssueNetwork not Accessible While a USB Connection to a Host is ActiveColibri T20, Colibri T30, Apalis T30Ethernet, USBCE6, WEC7
Description: While the Windows CE device's USB client port is connected to a host (e.g. for debugging), the network connection is not accessible. Reason: The USB client connection creates a virtual COM port COM0 and an additional network connection through COM0. The Windows CE device's network traffic is then routed to COM0 by default.
Workaround: Use the Windows CE command line to change the routing table: 1. route print com0 Look at the COM0: row in the interface list, and remember the number shown in the first column . 2. route delete 0.0.0.0 IF Where i is the number taken from step 1. Repeat these steps each time you disconnect and re-connect the USB cable.
