Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V1.4beta3 (Release date: 2015-07-31)
This is the release candidate for V1.4
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2015M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2015M06
- WEC 2013 Updates: Installed Updates until 2015M06
WC-2088FixedSuspend does not work when USB is connectedColibri T20Kernel, Power Management, USBCE6, WEC7
Description: Module will not suspend if a device is attached to the USB Client port (i.e. Active Sync). In rare cases suspend also does not work with a USB memory device attached.
Workaround: Detach USB Host / Client before suspending.
