Search by Tags
Toradex CE Libraries Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex CE Libraries.
Issues which are scheduled for a specific version (e.g. V1.1) will be integrated in the mentioned version of the Libraries.
Clear Filter
2.1 (Release date: 2018-01-12)
- Added CANLib for Tegra
- Improved SPILib performance and fixed default pin mappings
- Improved I2CLib
- Improved CANLib performance
WCL-437FixedCAN: CAN_Write function does not return correct length on i.MX6, Vybrid and i.MX7Colibri iMX7, Apalis iMX6, Colibri iMX6, Colibri VF50, Colibri VF61CANCE6, WEC7, WEC2013
Description: The function has a counter that starts at -1 (error) and adds the number of bytes sent for each packet, returning one byte less than the actual amount sent. If you send a zero length packet, the return value is still -1, meaning error.
