3D CAD Models
Verdin Family
Verdin Modules
Toradex provides two different 3D models for Verdin Systems on Module:
Generic 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Verdin modules as well as future releases.
- Specific 3D Mechanical Models: These models are simplified models of the respective Verdin module. They contain only the PCB and the CPU and are intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different.
The generic Verdin 3D model contains the PCB and the maximum component height on top and bottom of modules from the Verdin Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Verdin modules as well as future releases.
The Verdin iMX8M Plus 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Verdin modules as well as future releases.
The Verdin iMX8M Mini 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Verdin modules as well as future releases.
Older Verdin iMX8M Mini V1.0 Models
Verdin Industrial Heatsink
Verdin Industrial Heatsink Type 1
Verdin Industrial Heatsink Type 1 V1.1A
- Verdin Industrial Heatsink Type 1 V1.1A 3D STEP models
- Verdin Industrial Heatsink Type 1 V1.1A 3D EASM models
Verdin Industrial Heatsink Type 1 V1.0B
- Verdin Industrial Heatsink Type 1 V1.0B 3D STEP models
- Verdin Industrial Heatsink Type 1 V1.0B 3D EASM models
- Verdin Industrial Heatsink Type 1 V1.0B 3D PDF models
Verdin Carrier Boards
Verdin Development Board Mechanical Models
A basic 3D model for the Verdin Development Board V1.1 can be downloaded here:
Older Verdin Development Board V1.0 Models
Dahlia Carrier Board Mechanical Models
A basic 3D model for the Dahlia Carrier Board V1.1 can be downloaded here:
Older Dahlia Carrier Board V1.0 Models
Mallow Carrier Board V1.1A Mechanical Models
A basic 3D model for the Mallow carrier board can be downloaded here:
Apalis Family
Apalis Modules
Toradex provides two different 3D models for Apalis Systems on Module:
Generic 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
- Specific 3D Mechanical Models: These models are simplified models of the respective Apalis module. They contain only the PCB and the CPU and are intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different.
The generic Apalis 3D model contains the PCB and the maximum component height on top and bottom of modules from the Apalis Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Apalis modules as well as future releases.
The Apalis iMX6 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
The Apalis T30 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic Apalis 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
Apalis TK1 - Specific 3D Mechanical Models
The Apalis TK1 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic Apalis 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
Apalis Heatsink
Apalis Heatsink Mechanical Models
It is a generic STEP model that can be opened and modified in any 3D CAD. It includes Type 1, 2, 3 and 4.
Apalis Carrier Boards
Apalis Evaluation Board Mechanical Models
Apalis Evaluation Board V1.2
A basic 3D model for the Apalis Evaluation board can be downloaded here:
Apalis Evaluation Board V1.1
Ixora Carrier Board Mechanical Models
A basic 3D model for the Ixora Carrier Board V1.3 can be downloaded here:
Ixora Carrier Board V1.2 Models
Ixora Carrier Board V1.1 Models
Ixora Carrier Board V1.0 Models
Colibri Family
Colibri Modules
Toradex provides two different 3D models for Colibri Systems on Module:
Generic Colibri 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
- Specific Colibri 3D Mechanical Models: These models are simplified models of the respective Colibri module. They contain only the PCB and the CPU and are intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different.
The generic Colibri 3D model contains the PCB and the maximum component height on top and bottom of modules from the Colibri Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Colibri modules as well as future releases.
Colibri iMX6 - Specific 3D Mechanical Models
The Colibri iMX6 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic Colibri 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
Colibri VFxx - Specific 3D Mechanical Models
The Colibri VFxx 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic Colibri 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Colibri modules as well as future releases.
- SolidWorks CAD model 3D EPRT model
- 3D STEP models that can be opened and modified in any 3D CAD. The simplified model does not contain any copper pads.
Colibri Carrier Boards
Colibri Evaluation Board Mechanical Models
A basic 3D model for the Colibri Evaluation Board can be downloaded here:
Viola Carrier Board Mechanical Models
Viola Plus
A basic 3D model for the Viola Plus Carrier Board can be downloaded here:
Viola
3D CAD model for previous versions of the Viola Carrier Board can be downloaded from the archive:
Aster Carrier Board Mechanical Models
A basic 3D model for the Aster Carrier Board can be downloaded here:
Iris Carrier Board Mechanical Models
A basic 3D model for the Iris carrier board can be downloaded here:
